Démontage winch GIBB 16STA
09 Nov 2015 16:41 - 09 Nov 2015 16:42 #11368 par Sea You
Réponse de Sea You sur le sujet Démontage winch GIBB 16STA
Pour faire avancer le shmilblik et ressortir du fond du tiroir le problème, je viens de tomber sur 2 photos qui montrent le démontage de Winch Gibb ST25. Le principe me semble identique au 16 STA.
On vois nettement un pas de vis solidaire du doigt du Winch
01 Fév 2009 17:10 #1439 par
Réponse de sur le sujet Re:Démontage winch GIBB 16STA
Pour les adeptes de shakespeare
1. Remove snap ring (#8) using a screwdriver or a small pointed object. (Remove using a spiral motion rather than pulling straght up.)
2. Simultaneously, lift drum (#1) and cover (#3) from base (#2).
3. Remove cover (#3) from drum (#1).
4. Remove two pawls (#5) and two springs (#8) from drum (#1).
NOTE: TO PROCEED FURTHER, BASE (#2) MUST BE REMOVED FROM DECK OR MAST.
5. Remove two bearings (#7) from base (#2).
6. Inspect two pawls (#5) and springs (#6) on base Clean and oil. (Do not remove unless broken.)
7. Using a spiral motion, remove snap ring (#8) on bottom of base (#2).
8. Remove main shaft (#4) from base (#2).
9. Carefully wash pawls, springs, bearings, main shaft, base, and inside of drum.
10. Lightly grease inside of base (#2).
11. Assemble main shaft (#4) into base (#2).
12. Assemble snap ring (#8) onto bottom of base (#2), seating securely into groove on mainshaft (#4). (Use spiral motion.)
13. Grease two bearings (#7).
14. Assemble two bearings (#7) onto base (#2).
15. Assemble two pawls (#5) and two springs (#6) to drum (#1) noting correct pawl position as shown on exploded drawing.
16. Assemble drum (#1) onto base (#2).
17. Oil assembled pawls (#5) on drum (#1).
18. Rotate drum (#1) to check freedom of movement.
19. Assemble cover (#3) over top of drum (#1).
20. Assemble snap ring (#8) over cover (#3) seating securely into groove of main shaft (#4). (Use a spiral motion as when removed rather than shoving straight down.)
01 Fév 2009 17:02 - 01 Fév 2009 18:44 #1438 par
Si ca peut aider j' trouver ca, traduction a l' arrache...
1. Supprimer un composant logiciel enfichable ring (# 8) à l'aide d'un tournevis ou un petit objet pointu. (Suppression de l'aide d'un mouvement de spirale plutôt que de tirer straght place.)
2. Simultanément, un ascenseur à tambour (# 1) et couvrir (# 3) de la base (# 2).
3. Retirer le couvercle (# 3) de tambour (# 1).
4. Retirez les deux cliquets (# 5) et de deux ressorts (# 8) de tambour (# 1).
NOTE: Pour poursuivre, BASE (# 2) doit être retiré de pont ou de MAST.
5. Retirez les deux paliers (# 7) de base (# 2).
6. Inspecter les deux cliquets (# 5) et des ressorts (# 6) sur la base de Propreté et de l'huile. (Ne retirez pas, sauf si cassé.)
7. Utilisation d'un mouvement de spirale, retirez snap ring (# 8) sur fond de base (# 2).
8. Suppression de l'arbre principal (# 4) de la base (# 2).
9. Laver soigneusement les cliquets, ressorts, roulements, l'arbre principal, la base, et à l'intérieur du tambour.
10. Graisser légèrement l'intérieur de la base (# 2).
11. Montez l'arbre principal (# 4) dans la base (# 2).
12. Assemblez snap ring (# 8) sur fond de base (# 2), solidement assise sur mainshaft en rainure (# 4). (Utilisez mouvement de spirale.)
13. Graisser deux roulements (# 7).
14. Assemblez deux paliers (n ° 7) sur la base (# 2).
15. Assemblez deux cliquets (# 5) et de deux ressorts (# 6) à tambour (# 1) en notant la position correcte cliquet explosé comme indiqué sur le dessin.
16. Assemblez tambour (# 1) sur la base (# 2).
17. Oil assemblés cliquets (# 5) sur le tambour (# 1).
18. Rotation du tambour (# 1) pour vérifier la liberté de mouvement.
19. Assembler la couverture (# 3) sur le dessus du tambour (# 1).
20. Assemblez snap ring (# 8) sur la couverture (# 3) sièges solidement en rainure de l'arbre principal (# 4). (Utilisez un mouvement de spirale que lorsque enlevé plutôt que de pousser vers le bas.)
01 Fév 2009 16:30 #1437 par
Essaie sur ce site: www.cncphotoalbum.com/indexes/winches.htm
Peut-être, un des éclatés peut t'aider (en anglais...)
B) Roro
01 Fév 2009 16:07 #1436 par Sea You
Réponse de Sea You sur le sujet Re:Démontage winch GIBB 16STA
C sympa Almo :)
Mais malheureusement je n'ai pas d'éclaté sauf celui de Lewmar mais qui ne correspond pas à ce modèle GIBB :(
01 Fév 2009 15:57 #1435 par
montage sous presse peut être tu as un éclater,un plan,
je suis dessinateur en mécanique, si je peux t' aider...
Almo
01 Fév 2009 15:47 #1434 par Sea You
C'est une encoche où la rondelle du chapeau vient se loger
01 Fév 2009 14:37 #1433 par
c est une cassure ou une encoche sur la 2eme photo ?
01 Fév 2009 14:26 #1432 par Sea You
Eh non
C'est tout rond aucune encoche
01 Fév 2009 14:18 #1431 par marinou
Réponse de marinou sur le sujet Re:Démontage winch GIBB 16STA
il n'y a pas une vis au fond de l'encoche pour la manivelle de winch ?
Sur mon FUN, le winch se démonte en enlevant une vis au fond de l'empreinte pour la manivelle.
Temps de génération de la page : 0.120 secondes
